Activity › Forums › Apple Final Cut Pro Legacy › dumping Sony Z1 footage into FCP4
Posted by Chongo on September 18, 2005 at 6:40 amFCP4 will not recognize the Z1. Anyone have advice on how to dump the footage?
Shot in HDV. I am down-converting to letterbox DV.
Thanks-
Chongo
Kevin Monahan replied 21 years ago 3 Members · 4 Replies -
Shane Ross
September 18, 2005 at 8:56 amWell, either capture the footage as DV, downconverted from the camera. Or use lumiereHD to capture the footage, or HDVxDV, or FCE HD that uses the Apple Intermediate Codec.
Or upgrade to FCP 5, which captures HDV natively.
Chongo
September 18, 2005 at 6:08 pmHi Shane-
I am trying to capture as downconverted DV, but FCP will not recognize that there is a camera attached…
-Chongo -
Shane Ross
September 18, 2005 at 8:36 pmIs it powered on BEFORE you open FCP?
Did you recently upgrade to quicktime 7? I mean, did it work before, then you upgraded and now it doesn’t? Has it ever worked?
Kevin Monahan
September 18, 2005 at 8:42 pmDoes it downconvert on the fly? Are you sure? I thought that it did DV, it did HDV but that you need a capture card to downconvert from HDV to DV.
Kevin Monahan
Author – Motion Graphics and Effects in Final Cut Pro
fcpworld.com
