Activity › Forums › Sony Cameras › dump clip to SxS and play on EX30?
Posted by Nick Lammers on October 21, 2009 at 2:14 pmHi. Editing in FCP and was wondering if I can render out a clip that I can then put on the card and play back on the EX30. Perhaps drop into the BPAV file? I could always play through the AJA and digitize/record to the EX30 but just trying to save a step. Thanks.
Nick Lammers
Media Mill, Inc.
St. Louis, MONick Lammers replied 16 years, 10 months ago 3 Members · 8 Replies -
Michael Palmer
October 21, 2009 at 2:17 pmYes you can get back to the EX Codec, export as Sony XD Cam. You first need to set the Sequence Audio tape to dual mono and you can put everything back as original. Craig Seeman has a nice little tutorial here somewhere showing each step.
Good Luck
Michael Palmer -
Nick Lammers
October 21, 2009 at 2:21 pmThanks Michael. I believe I can handle that (maybe :). I will also look up Craig’s tutorial.
Nick Lammers
Media Mill, Inc.
St. Louis, MO -
Nick Lammers
October 21, 2009 at 6:36 pmHmmm. I believe I followed the steps correctly but when I go to the EX30 and hit “thumbnail” I get a “no clip” message. I tried exporting directly to the deck and also to a hard drive and then copying to the deck. Any other thoughts? Thanks.
Nick Lammers
Media Mill, Inc.
St. Louis, MO -
Nick Lammers
October 21, 2009 at 6:45 pmHang on – just found another thread with more advice. Let me try a couple more things.
Nick Lammers
Media Mill, Inc.
St. Louis, MO -
Nick Lammers
October 21, 2009 at 7:30 pmOK. Wasn’t using clip browser to export before – now everything is fine. Thanks for all of the help.
Craig, I would like to know which screen capture ap you are using.
Nick Lammers
Media Mill, Inc.
St. Louis, MO -
Craig Seeman
October 21, 2009 at 8:16 pm[Nick Lammers] “Craig, I would like to know which screen capture ap you are using. “
Telestream ScreenFlow. It’s got a whole bunch more features than I’m using.
https://www.telestream.net/screen-flow/overview.htm
It’s great whether you’re trying to do full blown tutorials or simply show a feature or issue that would be hard to get across with text.
BTW it works well if you’re shooting with your EX and need to grap screen video at equally hi rez. It’s fully integrated with your QuickTime codecs which means you can export to EX .mov or Apple ProRes for easy integration of screen video with your editing work. -
Nick Lammers
October 22, 2009 at 1:11 pmThanks Craig. I occasionally have to record power point presentations – I will check it out and see if it would be a better option than the scan converter/DVCam deck.
Nick Lammers
Media Mill, Inc.
St. Louis, MO
