Activity Forums Adobe After Effects Dumb Question, I know… But… Compression Q
  • Dumb Question, I know… But… Compression Q
    Posted by Ricardo Nichols on October 17, 2008 at 1:44 pm
    So, I assume this is a stupid question.
    But, would someone just answer it. Even if you say…
    The answer to your stupid question is _____.
    The question:
    I’ve been asked to supply “Uncompressed” video to someone. That is done by selecting “None” for the Compression Type?
    They also mentioned the files being 10 bit? I see no option in the Render Settings or Output Modules to specify something like that…
    Help?
    Kevin Camp replied 17 years, 11 months ago 3 Members · 4 Replies
  • Eric Sanderson
    October 17, 2008 at 3:11 pm
    Yes doing a NONE in quicktime is uncompressed. In that same dropbox there should be the options “uncompressed 8-bit or 10-bit”..usually at the very bottom.
  • Ricardo Nichols
    October 17, 2008 at 3:16 pm
    Okay, cool. Thanks for the clarification on NONE, Uncompressed…
    Although I see no choice anywhere for 8 or 10bit…
    Hmm….
  • Eric Sanderson
    October 17, 2008 at 3:52 pm
    hmm, it could be your set-up, im on AE CS3 with a G5 and blackmagic card, and i have the 8-10bit options…i think i get the uncompressed options through my blackmagic card though so that could be it.
  • Kevin Camp
    October 17, 2008 at 10:44 pm
    you can download the black magic codecs (they are free) here, they grouped by os on the right side of the page.
    your client would also need those codecs, though… you could give them those codecs, but they may have a 10-bit codec in mind (fcp, for example, has its own set of apple issued 8 & 10-bit codecs). so you might just ask what 10-bit codec they would like, and where you might be able to get it, or if they could just send it to you.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
