Activity › Forums › Adobe After Effects › Duik rig breaks when Global Controller is moved: even when precomped.
  • Duik rig breaks when Global Controller is moved: even when precomped.
    Posted by Jess Riley on October 15, 2016 at 11:17 am
    Hey guys,
    I am new to AE and have only used the Duik plugin once before (where it worked fine!) but for some unknown reason the visual of the puppets limbs will distort and not stay attached to the rig when moved or scaled with the GLOBAL controller from the position I originally rigged it in. I have converted all my Ai vector files to shapes in Ae & re rigged multiple times to try and get it to work.
    The controllers will still move the rig, and will move the shape successfully if it’s in the original position.
    I am about to pull my hair out! Anyone have any ideas?
    Jess
    Roei Tzoref replied 9 years, 11 months ago 2 Members · 1 Reply
  • Roei Tzoref
    October 15, 2016 at 4:16 pm
    you should make sure you only change your characters transformations using the puppet nulls and not the shape which is what probably is happening. you should not change any of the transformations of the shape layer when using puppet pin. it’s a render order thing. shape layers are collapsed by default and this means the render order is in reverse that usual. first the transformations, then the puppet. imagine you are scaling or moving a layer through a mesh of puppet – this is what happens. the way to solve it is not scale or move
    what you should do is precomp the whole shape structure with the puppet animation (don’t use the collapse switch for the precomp) now you can move the whole thing if you want. or don’t convert to shapes and use the original Ai layers without turning the continuously rasterize switch.
    this is from the help files: https://helpx.adobe.com/after-effects/using/animating-puppet-tools.html
    Note: Don’t animate the position or scale of a continuously rasterized layer with layer transformations if you are also animating the layer with the Puppet tools. The render order for continuously rasterized layers—such as shape layers and text layers—is different from the render order for raster layers. You can precompose the shape layer and use the Puppet tools on the precomposition layer, or you can use the Puppet tools to transform the shapes within the layer. (See Render order and collapsing transformations and Continuously rasterize a layer containing vector graphics.)
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
