Activity Forums Adobe After Effects Duik Problem – Updated PS File created an anomaly
  • Duik Problem – Updated PS File created an anomaly
    Posted by Gerald Hapeman on February 2, 2014 at 7:26 am
    I created a run cycle – simple enough. Works perfectly. Since then, I had to adjust one of the arms in photoshop (shaved away with the eraser tool a bit of an axe blade). When I play the file back in AE, there is a weird anomaly of what appears to be bits and pieces of the arm I edited (but not where I erased) scattered on the arm, like it duplicated itself in bits and pieces. See picture. I tried to reload footage and that does nothing… I tried to erase them, but if I do, I must erase every frame, but even so, it leaves or punches holes onto the composition so that when the axe does pass through where I erased, it doesn’t show… as if I erased. HELP!?
    Gerald Hapeman replied 12 years, 3 months ago 49,231 Members · 1 Reply
