Activity Forums Adobe After Effects Duik Foot Roll doesn’t work
  • Duik Foot Roll doesn’t work
    Posted by Dorota Sloma on August 11, 2021 at 4:38 pm
    I keep having a problem with Duik Foor Roll, after rigging leg with bones the Toes don’t work, there is no bend. Everything else works fine just this, I can’t find the solution. Does anyone know how to solve it? I attach screenshots.
    Dorota
    Dorota Sloma replied 5 years ago 2 Members · 3 Replies
  • Graham Quince
    August 14, 2021 at 11:09 am
    Have you had this working in previous characters? If so, then maybe when you ran the script something didn’t link up. You could tray expanding the ankle joint expression and checking the toes match the settings. Alternatively if you have used this in the past, then you could try starting again.
    If this it the first time you’ve used it in this way and it happens again, it might be a bug in DUIK’s code. They’ll thank you for reporting it.
  • Dorota Sloma
    August 15, 2021 at 10:31 pm
    it actually happened before,I will report it to them, thank you 🙂
  • Dorota Sloma
    September 14, 2021 at 9:49 am
    I solved the mystery – it’s all about Bone parenting. So by default bone which correspond with a tiptoe is parented to the tiptoe structure, when I change it and parent it to the toe structure all works fine.
