Activity › Forums › Apple Final Cut Pro Legacy › Dueling Log and Transfer Plugins
  • Dueling Log and Transfer Plugins
    Posted by Mike Petty on January 1, 2011 at 10:39 pm
    Here’s an interesting dilemma. I shoot on a Sony EX3 and a Canon 7D. Both Sony and Canon have their own log and transfer plug in. I normally use the Canon software inside FCP for L&T and use Sony’s external software to do selects and footage conversion..then just import those files into FCP.
    However that software has been giving me fits and I want to use the Sony L&T plug in for FCP.
    The question is…can the two L&T plug ins co-exist. How do I or FCP know which is the right on for the task at hand. Will it it self select based on what media I want to import from SxS cards from the Sony or SD cards from the 7D (I seriously doubt its that easy but I had to ask)?
    Guidance…?
    MP
    Michael Gissing replied 15 years, 9 months ago 2 Members · 1 Reply
  • Michael Gissing
    January 2, 2011 at 12:36 am
    The L&T plugins also include RED. Obviously you would not be doing folders with mixed codecs so the plugins must work when the specific folder/ file structure is recognised for each format. So do the 7D folders and then do the XDcam folders. L&T will work it out. Obviously you will have to check the prefs for each plugin to make sure you are outputting a common codec (like ProRes422)
