Activity Forums Panasonic Cameras dubbing from Firestore to DV tape
  • dubbing from Firestore to DV tape
    Posted by Itamar Kool on February 18, 2007 at 12:01 pm
    I posted this question also on the Firestore COW:
    I tried and I tried but I can’t seem to find how to dub the files from my Firestore version 3 to DV. I recorded it in DVCPRO HD in my HVX 200 and now I want mo make a DV tape in the camera. I can play out the files to the LCD display and the monitor, but when I put the camera in dubbing mode, it doesn’t see the Firestore anymore
    Kool En De Anderen
    dual 1.8 gig G5/Mac OS 10.4.8/Kona 2/Hugh 800 G diskarray, fibrechannel/FCP 5.1.2/AE 7 Pro
    http://www.koolendeanderen.nl
    Itamar Kool replied 19 years, 6 months ago 3 Members · 4 Replies
  • Tony Cope
    February 18, 2007 at 6:30 pm
    One problem is that in order for the camera to recognize the Firestore HD files, you must be in the P2 mode. As far as I can tell, the miniDV tape will only operate in the TAPE mode – and it will only record in DV resolution… so you would not be able to transfer the HD resolution to miniDV tape.
    If you need to make a miniDV copy of the footage, you might try loading it onto a computer with firewire, convert the file to standard def. – then run the firewire into your camera and record to tape using the firewire input with the camera in TAPE mode.
    Hope this helps,
    Tony
  • Itamar Kool
    February 19, 2007 at 9:44 am
    Kool En De Anderen
  • Barry Green
    February 19, 2007 at 5:30 pm
    You can’t do it. Dubbing/downconverting only works from a P2 source, not from the FS-100.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Itamar Kool
    February 19, 2007 at 8:17 pm
    Well at least I know now that I don’t have to try anymore. Thanx
    Kool En De Anderen
