Activity › Forums › VEGAS Pro › Dual/double layer DVD-R
  • Dual/double layer DVD-R
    Posted by Charles Avanti on January 11, 2008 at 6:00 pm
    I will soon have a SD project that may be two hours long. I was wondering if anyone has burned any SD videos to a Dual layer DVD with DVD Architect and if there are any playback compatibility problems associated with them?
    What version of DVD Architect is needed to do this? Also, what dual layer burner do you recommend?
    Charlie
    Charles Avanti replied 18 years, 8 months ago 3 Members · 11 Replies
  • 11 Replies
  • Edward Troxel
    January 11, 2008 at 6:38 pm
    You can easily put 2 hours on a single-layer DVD. I wouldn’t worry about trying to use a dual-layer.
    Edward Troxel
    JETDV Scripts
  • Charles Avanti
    January 11, 2008 at 8:39 pm
    Thanks Ed. How good is the 2 hour SD picture when the 16:9 SD is shown on a 26″ to 50″ HDTV?
    Charlie
  • Mike Kujbida
    January 11, 2008 at 8:47 pm
    Charles, it depends on how good the master was.
    For example, a 2-hr. play that I shot last year (in 16:9 mode) on a Sony DSR-500 (broadcast-grade DVCAM unit) looked great on a 46″ LCD.
  • Charles Avanti
    January 11, 2008 at 8:58 pm
    Thats good news. Could you please post the render setings you used for that project length?
    Charlie
  • Edward Troxel
    January 11, 2008 at 9:22 pm
    You can download a bitrate calculator. I have a chart in Vol 1 #7 of my newsletters.
    Edward Troxel
    JETDV Scripts
  • Charles Avanti
    January 11, 2008 at 9:33 pm
    I have a BR calc, but I was curious as to his settings used. I have tended to stay with a high (7,500,000) CBR, but that won’t fit on a 2 hour show. Would VBR be best for a 2 hr. show, if so then there are more variables.
    Charlie
  • Edward Troxel
    January 11, 2008 at 9:45 pm
    Without looking, I believe the average bitrate (using VBR) would need to be about 4,825,000.
    Edward Troxel
    JETDV Scripts
  • Mike Kujbida
    January 11, 2008 at 9:59 pm
    Charlie, Edward has been at this a lot longer than I have so I’d listen to him 🙂
    Since you asked though, for a 2 hr. DVD, my bitrate calculator says:
    CBR: 4,576,000
    VBR: 8,008/4,576,000/2,744,000
    BTW, I’ve got it set to a 5% safety margin instead of the default 1% which is why my numbers are a bit lower than Edward’s.
  • Charles Avanti
    January 11, 2008 at 10:16 pm
    Thanks guys,
    If I want to do a DVD-9, is this a pre-set choice in DVDA using a mpg2 from Vegas?
    I have Vegas 6 and DVDA 3.
    Charlie
  • Edward Troxel
    January 11, 2008 at 11:28 pm
    Look at Vol 1 #7 and Vol 4 #1 of my newsletters. They explain the entire process.
    The basics:
    Render from Vegas as MPEG2 picking one of the DVD Architect presets using the “Custom” button to change the bitrate.
    Render from Vegas as AC3 for the audio
    Use those two files in DVD Architect to create the final DVD.
    Edward Troxel
    JETDV Scripts
