dual pass rendering, How is it done?
Posted by Walter Mitty on June 26, 2005 at 2:01 pmI know this is probably as simple as the nose on my face, but I am failing to understand how to render an uncompressed peice with Divx5 pro to dual pass. I have rendered it once using the first pass setting, but now I find myself staring at the screen and asking “what now”? Do I simply encode a second time using the nth pass setting to the same file name and location? I have to admit that I am totally lost on this. A kick in the right direction would really be appreciated.
Outside of a book, a dog is man’s best friend.
Inside of a dog, it’s too dark to read.Walter Mitty replied 21 years, 3 months ago 4 Members · 10 Replies -
Mike Kujbida
June 26, 2005 at 4:22 pmThe two-pass option is available only if you select an mpeg-2 render. Otherwise, it’s single pass.
Walter Mitty
June 26, 2005 at 6:33 pmummm… Now I am confused. The DIVX5 codec window has a setting for 2 pass rendering. I am doing some sort of second pass now with it and something is happening. Not sure if it is what I want though. I really have to get up to speed with the differant codecs and what works best in which situation. I have just begun converting a large number of Hi8, S-VHS, and some 8mm films to digital. I really need to get a firm handle on all this so that I do not waste time and have to redo anything. Right now, I am working with videos that are not so important to me so a little loss in quality won’t kill me. But my wedding videos, family reunions of folks long gone, and the videos from my grandparents (caught on film and transferred to Hi8mm) are really important to me, so I want to get it right. Someone suggested to me using either the VP6 or 3ivx codecs for a better quality of encoding. For now, all this will reside on Harddrives, but eventually I will want to transfer it all to DVD (once I get a burner) for archival purposes and sharing with distant family.
Thanks for the help. Everytime I learn something, it illuminates the fact that there are 10 more things I don’t know.
Mike Kujbida
June 26, 2005 at 8:48 pmAh, Divx. Now I see where you’re getting the 2-pass option.
I do question the use of this codec though for projects that, to quote you ” are really important to me, so I want to get it right.”
If they’re that important, I’d strongly recommend forgetting about Divx and sticking with what Vegas likes – DV-AVI. Staying with this format gives you a lot more editing flexibility and, IMO, less headaches down the road. -
Walter Mitty
June 27, 2005 at 1:50 amI follow what you are saying now and from what I have read today I think I got to get with it on the codec choices. What exactly is DV AVI. I know AVI, but what does the DV denote that I should know? Digital Video? I want to basically get something that might pass through a second render once edited to give a decent finished product. Kind of a learning curve for me.
Outside of a dog, a book is man’s best friend.
Inside of a dog, it’s too dark to read. -
Edward Troxel
June 27, 2005 at 2:58 am -
Alan Roth
June 27, 2005 at 11:08 amI think there may be some confusion on what two-pass encoding is. I am no expert but I think two-pass encoding means that the encoder makes one pass through the entire file to determine how best to encode it, then makes a second pass applying knowledge gained from the first. So to you it looks like a single pass or “run”, but it takes a long time. In other words, you don’t run it once, then after it’s finished tell it to run again. The first and second passes are done automatically when you run it once. Hope this doesn’t confuse things further…
Mike Kujbida
June 27, 2005 at 2:47 pmI want to basically get something that might pass through a second render once edited to give a decent finished product.
No worries with Vegas on this issue whatsoever. The encoder is recognized as being one of (if not the) best around.
Mike
Walter Mitty
June 27, 2005 at 2:54 pmI have actually found that I had to run it twice and the second time it loaded a log file with the dat from the first pass, presumably to adjust the compression settings as the second pass was conducted. I ran one through last night using 3ivx, and it was really a BIG improvement from what I have been seeing. I think this might be my choice for the time being to work from. That way I can run from this a second de-interlaced copy in VDUB ( I don’t know how to deinterlace via a fliter, or even if there is one, in Vegas 4), and edit all this up for final presentations for the interlaced versions for family. Thanks all.
Walter Mitty
June 27, 2005 at 3:11 pmThanks for the knowledge Edward. I learned something. Too bad that it will do nothing for me since I am using the VIVO on my TI4200 video card for capture from an Analog HI8 Canon. I plan on trying to upgrade to a Panasonic GS400 this fall, so that will be when I get to use the firewire.
Walter Mitty
June 27, 2005 at 3:14 pmThanks Mike. I just started working with all this in ernest, so I am not so competant with it as yet. I found the 3ivx codec yesterday and was pretty impressed with the final product in comparison to DIVX5. I think this is what I will be using for the immediate future until I find something better.
