Activity Forums Apple Final Cut Pro Legacy Dual Monitor woes
  • Dual Monitor woes
    Posted by Luke David on March 16, 2009 at 1:41 pm
    I am running a Power Mac g5/power pc 970 (2.2) with 1GB memory and my display card is an ATI Radeon 9600 Pro. For the past several years I have been editing lots of dv footage using two Viewsonic 17″ monitors. I recently inherited two 23″ cinema HD displays (the acrylic ones) and I can only get one to work. I can run one of them and one of the viewsonics, but once I plug in the 2nd 23, it goes black and the other one (that was working) becomes the second display. The Radeon card has a DVI and ADC input so I am using one converter (DVI to ADC) to hook them both up. The literatureI have read seems to indicate that this card can handle both, in fact that is what they told me at one Apple reseller. The converted signal is the one that works while the direct to DVI input is the one that always goes black. I have tried swapping the monitors with the same result, so I beleive they are both operational. Do I need new card? and if so which can you recommend? Thanks in advance for any help.
    Luke David replied 17 years, 5 months ago 3 Members · 4 Replies
  • Walter Biscardi
    March 16, 2009 at 2:23 pm
    [Luke David] “The Radeon card has a DVI and ADC input so I am using one converter (DVI to ADC) to hook them both up”
    Can’t run both off one port if that’s what you’re doing. One goes into the ADC and one goes to the DVI.
    On a side note, 1GB of RAM is woefully low. 2GB Minimum, 4GB better.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Jerry Hofmann
    March 16, 2009 at 3:58 pm
    Soooo when the converter is used, no signal? I’d suspect the converter might be the problem, and if it’s not, it’s the card itself. Is there a way you can connect the DVI port directly to rule out the card?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Walter Biscardi
    March 16, 2009 at 4:05 pm
    [Jerry Hofmann] “Soooo when the converter is used, no signal? I’d suspect the converter might be the problem, and if it’s not, it’s the card itself. “
    If it’s one of those unpowered converters, it definitely won’t work. We had to purchase the $100 Dr. Bott DVI to ADC converters in order to make our old ADC monitors work with DVI.
    I actually just threw two of them away.
    Read my Blog!
  • Luke David
    March 16, 2009 at 5:32 pm
    Not using two on one port, not even sure that is possible, but I do have both monitors into one card – one in the DVI and one in the ADC (after going through the powered converter). And the monitor with the converter is the one that is working. Is the memory the issue? New card? Additional card?
