Activity › Forums › Adobe After Effects › dual monitor question
Posted by Joe Mcarthur on August 28, 2006 at 4:48 pmhow do i get my comp window to move to my second monitor . . . simply draging it doesn’t work . . . i want all of my video previews to show up on monitor 2 . . . is there a setting or preference i need to change in AE . . . thanks
Todd replied 20 years ago 5 Members · 5 Replies -
Mylenium
August 28, 2006 at 6:51 pmWhat version of AE are you using? Should be no problem in AE 7, but in older versions certain interface elements cannot exist outside the main window. You would then need to maximize you main window to both screens.
Mylenium
[Pour Myl
Ruediger Meier
August 29, 2006 at 8:40 am -
David Dubois
August 29, 2006 at 10:43 amIf you’re on a pc then ‘un-maximise’ the main window and drag the main window’s grey area so that it covers both screens. You can then move AE 6.5’s windows where-ever you want inside its work area.
Hope that helps.
Dave
Best quote from a client so far
‘I meant more of a blueish black and white’ -
Todd
August 29, 2006 at 3:41 pmI agree with what DDubious said. I’ve been using AE on duel monitors since version 5 I believe on my PC with no problems. There is no setting in AE to do it, it is simply a matter of how you have your dual monitor setup configured with your graphics card.
Some graphics cards come with software that will add another icon on toolbars next to the max/min/close icons that will basically maximize the window to both monitors. It works, but I found it buggy sometimes in the past so stopped using it.
What I have used for years now is just what Dubious said. You simply UNmaximize your AE window, then manually drag the width of it across both monitors. At that point you can put whatever you want on either monitor. Basically it sounds like your AE window is maximized to your primary monitor therefore you can obviously not drag anything outside of the AE window (or onto your second monitor in this case), unmaximizing and manually scaling your AE app windwo to both monitors solves this.
