Dual frame rates w/ dual sound syncing problems….deadline approaching
Hi Gurus,
I’m trying to edit a dual sound, multi cam sequence in FCP7 (10.8.1). Problem is a third of the footage is 23.98 while the bulk is 25fps. I conformed the 24P to 25 with QT Edit (lost cinema tools in an update). Pluraleyes has successfully synced the 25p stuff, but won’t sync the stuff thats been conformed. Figuring thats because the footage and guide track has been stretched 104.08% and pluraleyes cant match the waveforms? Am I on the right track here with this? I’ve wasted a day trying to sort this and am running out of time. Any help or advice you have on cutting together with the 2 frame rates and dual sound would be great (apart from “don’t do it”).
Dimitri
