Activity › Forums › VEGAS Pro › DSR-25 and Vegas
  • DSR-25 and Vegas
    Posted by Brian Scott on December 21, 2006 at 12:44 pm
    I am trying to get Vegas to print out to my DSR-25 without much luck. I have searched the forums but find no other reference to the 25. Will this deck work with Vegas? It captures fine, but when I go through the print to tape command, I get the the last page where you select crash record, etc. and none of the options are available. When I try print to tape from the capture utility, I get an error – Be sure device can accept input. It is set to DV in. Any ideas?
    Brian Scott
    President
    Image Design Productions, Inc.
    Tom Pauncz replied 19 years, 9 months ago 2 Members · 1 Reply
  • Tom Pauncz
    January 7, 2007 at 6:41 pm
    Brian,
    I just saw your post. I have a DSR-25 in my edit suite and have used it to print-to-tape with Vegas 3 thru’ Vegas 6. Have had zero problems – ever. Have not yet tried with Vegas 7, but have used it to capture successfully.
    Right now it’s unhooked as the edit suite has been relocated, but I can check the DSR-25 setup options if you still have not resolved the issue. As far as Vegas is concerned it sees it as an OHCI device (from memory).
    Tom
