Activity › Forums › Apple Final Cut Pro Legacy › DSR-11 deck not recognized by FCP?
  • DSR-11 deck not recognized by FCP?
    Posted by Tommy_bee on August 15, 2007 at 4:36 pm
    For a year I had my Sony DSR-11 connected to my Power Mac G5 FCP system with no problems. I disconnected the deck for a week and when I reconnected it Final Cut didn’t recognize the deck (no firewire device). I’ve changed wires, ports and checked settings with no luck. The deck works fine in every other way. I plugged the deck into my firewire drive and it disconnected the drive from my system (device removal). Is this a deck setting? Is the Firewire port bad? any clues? Thank you in advance!
    -Tommy
    Eric Peterson replied 19 years, 1 month ago 3 Members · 2 Replies
  • David Bogie
    August 15, 2007 at 7:33 pm
    Resetting the firewire bus can be as easy as restarting the Mac or as weird as pushing that freaky little button on the magic mother board; PMU, I believe it’s called.
    You can try the apple.com forums, hardware, and search carefully for firewire problems.
    I wish you luck but if you’re sure the port is good, that leaves the deck or the deck’s FW connection. You must eliminate one thing at a time and that often means having another Mac to hook up to your dsr11.
    bogiesan
  • Eric Peterson
    August 15, 2007 at 8:00 pm
