Activity › Forums › Apple Final Cut Pro Legacy › DSR-11 Deck acting up
Posted by Martin Sterling on January 31, 2007 at 1:26 amI recently purchased a SONY DSR-11 deck and I have been getting weird behavior when connecting to my computer. When it is connected from turning my Mac on, some of my drives wont mount as well as FCP will not open. It get stuck on its start up screen Im wondering if its a faulty firewire connection. Any thoughts.
G5 Dual 2.0 GHz processor, OSX.4.8
Martin Sterling replied 19 years, 8 months ago 3 Members · 5 Replies -
Shane Ross
January 31, 2007 at 1:36 amAll Macs have only one firewire bus, and often drives and other DV devices conflict over those ports. This might be the case.
If you get a PCI-X Firewire card, then you can add another firewire bus.
Shane
Littlefrog Post
http://www.lfhd.net -
Martin Sterling
January 31, 2007 at 4:05 ambut would that explain FCP freezing up upon launch.
Also, I recently did a 2 camera shoot, both cameras running side by side simultaneously. Both cameras were paused and started at the sametime. Both camera tapes have the same amount of TC breaks. Both tapes made a new clip the same amount of times. The only difference is that on tape, towards the end of the tape, the tape is missing footage at the end of the take. A minute or so in some cases. So, I think, the deck must be capturing the footage, always seeing the same breaks, but somehow disregarding some of the footage. This is only occuring when I use this deck. When I capture with my camera, I do not experience any of these problems.
Arnljot Bringedal
February 3, 2007 at 7:34 pmhave the same experience…
And as suggested I installed an extra firewire card….
Result:
DSR-11 working
FCP starting.What u have heard is true.
*** Norwegian videojournalist & Editor***
Martin Sterling
February 4, 2007 at 3:47 amThank You all. I have ordered my a firewire card from Macmall after going to the Mac Store on Staten Island and them not having it. So, in several days I will have it and install it and let you guys know. Thanks Again
Martin Sterling
February 6, 2007 at 12:14 amIs the above suggested action expected to vlean up my TV issies as well with the tape as I previously mentioned
