Activity › Forums › Avid Media Composer › DSLR with separate audio – workflow question
  • DSLR with separate audio – workflow question
    Posted by Paul Cuciti on October 18, 2012 at 2:44 am
    I need a good workflow for this scenario: footage was shot with a Canon DSLR with preferred audio tracks coming from a video camera. A clapboard was used to establish sync between cameras. Everything is loaded into the Avid.
    So of course i can get the track in sync with the picture, but I haven’t had occasion -before this- to work with the combined video/audio. What’s the best way to keep it together when cutting into a sequence? And just to complicate matters, the transcript was made from the audio tracks, using the the audio’s timecode ( the DSLR produced no timecode-everything starts at zero).
    I don’t want to reinvent the wheel, so I hope someone has a tried-&-true method for handling this.
    Paul
    Bouke Vahl replied 13 years, 11 months ago 4 Members · 4 Replies
  • Shane Ross
    October 18, 2012 at 4:27 am
    Group the clips. Mark IN where the slate appears on both, then Shift-Command-G. Group them…and then you can have a multicamera editing situation. If the logs are based on the video camera timecode, then have that as the main camera when you type in timecode numbers.
    Shane
    Little Frog Post
  • Pat Horridge
    October 18, 2012 at 8:17 am
    And when working with DSLR footage (pre the new 5DmkIII) Use QTchanger. to add timecode and reel id before you do anything with them.
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor
    VET
    Production Editing Digital Media Design DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
  • Paul Cuciti
    October 19, 2012 at 11:38 pm
    Thanks guys. I appreciate the info. So far it’s working just fine. I will be looking into that ‘changer’ app, too.
  • Bouke Vahl
    October 20, 2012 at 11:46 am
    Well, of course i support the QTchange routine,
    but do note, Avid does NOT take the Reelname when importing / ama in!
    (this is an Avid thing, not my fault…)
    If you need Reelname, export an ALE as well and link.
    (in the import dialogue, there must be something in the manual about it…)
    hth,
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
