DSLR video: color correction + exporting for web and for SD PAL DVD
Hello everyone!
I’m new to the DSLR workflow. Sorry for the long post.
I usually shot on my Canon 5D mark II (1920 x 1080 – 25fps – PAL) and transcoded to prores 422 to edit with FCP7 using Shane Ross workflow. https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
Now I have some questions:
1) What do you suggest to use for the color correction of my videos? After effects or FCP? When I shoot, I use Technicolor Cinestyle or Canon Neutral with minimal sharpness and contrast.
2)How do you prepare your videos for Vimeo? Do you use FCP or Compressor? Vimeo suggests to do that if you’re using Final Cut Pro 7 to edit your video https://vimeo.com/help/faq/uploading-to-vimeo/compression-tutorials#final-cut-pro-7 or https://vimeo.com/help/faq/uploading-to-vimeo/compression-tutorials#compressor-35 if you use compressor version 3.5 like me. Do you have any observations or comments?
3)How do you prepare your videos for an SD PAL DVD? What are the best presets for Compressor in order to get the highest quality videos results from FCP? I normally have videos between 10-20 minutes of duration and videos about 1 hour duration.
Thank you very much for your time!
