Activity › Forums › Adobe Premiere Pro › Dropping Frames
Dropping Frames
Posted by Kelly Johnson on March 28, 2006 at 6:23 amI have read every post and thread I can find. I have read every thing Adobe tells me to do. Since I started using PP 2.0 I have been dropping a lot of frames where I didn’t drop frames before. The only change has been the new software. Here are my specs:
Pentium 4HT, 2600MHz
1024 MB DDR SDRAM
NVIDIA GeForce FX 5200 (256MB)
WDC Firewire/USB2.0 IEEE 1394 SBP2 device
Scratch disks are 7500 RPM ULTRA-ATA/100Trying to capture using a Sony DCR-TRV33
If any one can help please do.
NickelJohnson
Kelly Johnson replied 20 years, 3 months ago 4 Members · 7 Replies -
Mike Velte
March 29, 2006 at 12:21 pmDropping frames is typically a hardware issue, but if you can still capture fine using PP 1.5, your PC might just be underpowered for 2.0 which consumes about 500 MHZ more CPU power than 1.5.
I can capture fine using a 2.8 P4 HT PC.
Are all virus/spyware scanners turned off?
Is your disc less than 75% full and defragged?
Are you trying to capture to an external device? -
Kelly Johnson
March 29, 2006 at 7:51 pmI have no spyware or virus software installed at all. My disc is only about 25% full and I defragged it the other day. I have tried capturing to each of my hard drives. I have an external hardrive and two internal and none of them performed better than the other.
Of times I have thought about the hardware issue. Is it more of a processor issue or a video card issue? I think I need a new video card any way but since my card is agp I would want to upgrade my motherboard and processor any way. -
Mike Velte
March 30, 2006 at 1:05 pmTry at test;
Copy/paste a video file about 100MB between drives. It should take about 3-4 seconds. -
Vince Becquiot
April 3, 2006 at 6:47 amHere’s an easy fix, go download the windv (https://windv.mourek.cz/) (Free)
It can even split files or separate audio/Video, or export to tape.
It uses a large memory buffer for capture, that should take care of your frame dropping isues.
Cheers,
Vince
Kelly Johnson
April 3, 2006 at 11:05 amThank you both for all of your help. I have realised that if I want to capture with Premiere I would need some new hardware. This little program will work perfectly till then. Again thank you both.
Brian
May 29, 2006 at 3:24 amInterestingly, I have exactly the same camera and am having the same problem with PP 2.0. In 1.5 I never had any trouble with dropped frames. Now I’m trying to capture to a newly-defragged 500GB drive that has ~250GB free. I have 1GB of memory and a 3.2GHz P4 with HT, which should be plenty of horsepower for a simple capture. The only change besides the software upgrade is moving from a Radeon 8500 video card to a new GeForce 6600 GT, but that’s an upgrade so I don’t know why that would be the issue unless there was some kind of interference from the video card driver.
Kelly Johnson
June 12, 2006 at 5:17 pmInteresting Brian,
I still haven’t figured it out but I have one idea. I think I will be getting a new MacBook Pro. FCP will solve the problem. Let me know if you have any ides that have worked. Plus I read you were in Utah, I am in Layton. Any way good luck.
