Activity Forums Apple Final Cut Pro Legacy Dropping frames on 444 capture.
  • Dropping frames on 444 capture.
    Posted by Panzer_baiken on December 15, 2007 at 5:46 am
    Hello. I’m trying to capture 1080 444 footage from HDCAM SR tapes to a 250mb/s RAID using a Kona 3 and the latest version of Final Cut. I’ve done it successfully many times, but lately, every time I try and capture I either get dropped frames or broken timecode when there is none. (I know there isn’t broken timecode because I’ve captured the same tape before.) The RAID seems to be performing fine, according to the Kona system test. I’ve tried multiple reboots, trashing prefs, but none of that helps. Does anyone have a clue as to what’s happening? Thanks in advance.
    Gary Adcock replied 18 years, 9 months ago 4 Members · 3 Replies
  • David Roth weiss
    December 15, 2007 at 7:11 am
    There’s a file you need to get from AJA that cures this issue. See this post for the file to ask for: https://forums.creativecow.net/readpost/8/956802
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Keicol
    December 15, 2007 at 10:31 am
    You need to download the Kona driver version 5 and use QT 7.3.1.
    However FCP is compressing the black gamma area of 10 bit RGB 444 clips in your project, so now the clips will play but they suck in the blacks.
    keicol
  • Gary Adcock
    December 15, 2007 at 2:32 pm
    [panzer_baiken] “Hello. I’m trying to capture 1080 444 footage from HDCAM SR tapes to a 250mb/s RAID using a Kona 3 and the latest version of Final Cut.”
    if you are capturing 10bit 24p your raid is just fast enough IMHO, and if it has less than 6 drives your captures may result in this kind of issue.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
