Activity Forums Blackmagic Design Dropped frames with DeckLink HD Pro PCIe + Xserve RAID + Final Cut Pro 5.0.4
  • Dropped frames with DeckLink HD Pro PCIe + Xserve RAID + Final Cut Pro 5.0.4
    Posted by Cesar Hashimoto on May 23, 2006 at 10:52 pm
    I’ve got a really sad situation where I have dropped frames about every 20 to 40 seconds in high def capture. Worse: I have TWO workstations identically configured, one of them worked fine in the start and now it has the behavior as the second one, which never captured more than half a minute without a drop.
    Here’s what I have (times 2):
    Power Mac G5 Quad 2.5 with 4GB RAM
    Mac OS X 10.4.6
    QuickTime 7.1
    Final Cut Pro 5.0.4 + Xserve RAID update (latency stuff)
    Decklink HD Pro PCIe + Decklink 5.5.1 Driver
    Apple Fibre Channel PCIe Card
    14-disk (7TB) Xserve RAID with 512MB cache per controller, Striped RAID 5 + RAID 5 (about 5TB free), 32K RAID Block Size, 8 Stripes drive cache
    Here’s what I’ve already tried:
    1. Captured 23.98psf HD uncompressed 10-bit to root of RAID volume
    results: failed (dropped frames about every 30 seconds)
    2. Captured 23.98psf HD uncompressed 8-bit to root of RAID volume
    results: same as above
    3. Captured 23.98psf HD DVCPRO HD to root of RAID volume
    4. Captured 23.98psf HD DVCPRO HD to Startup Volume (Macintosh HD)
    results: success (no dropped frames)
    Interestingly, hoping things were simpler to solve, I’ve even tuned FCP to limit the capture file sizes to <2GB and still it doesn't work.
    I was going to set the drive array to RAID 0, but RAID 5 should be fine for this. It doesn't seem to be a throughput question, once DVCPRO HD also dropped in test #3 (see above).
    Any ideas?
    ANY tip or suggestion would be of great help. In the meanwhile I'll try to reinstall fresh system on both of them and use an older set of driver+OS.
    Thanks in advance!
    Cesar Hashimoto
    Cesar Hashimoto replied 20 years, 3 months ago 4 Members · 8 Replies
  • 8 Replies
  • Bob Zelin
    May 24, 2006 at 1:51 am
    this is really sad, however you do state that you are doing RAID 5+ RAID 5, but you are not doing RAID 50. So you have an XServe RAID with 14 drives, but you are using them as 2 seperate 7 drive RAID 5 volumes ???? DONT DO THIS. You want ALL DRIVES striped together, so simply use the Apple Disk Utility to stripe your two RAID 5 volumes together to get a single RAID 50 volume, and try it again.
    But better yet, use the Blackmagic or AJA drive speed tests, and report back your findings. 7 drives is barely enough to do uncompressed HD at 1080i.
    Bob Zelin
  • Cesar Hashimoto
    May 24, 2006 at 5:54 pm
    Hey, I’m not THAT dumb. ;o)
    The 2 arrays were striped together as ONE big 5.5TB volume using disk utility. So it is a RAID 50 setup. In fact it has the same configuration as many other uncompressed HD FCP workstations I’ve setup. But none of them were PCIe with QuickTime 7.1. They were AJA Kona 2, actually.
    I did run the Blackmagic drive speed test and it returned about 300MBps for read and about 250MBps for write (not exactly but it was pretty much like that). That is well beyond the minimum througput necessary for 10-bit 4:2:2 uncompressed HD @ 1080p24 (which is about 125MBps). In fact, the results showed “25fps” for disk write @ 1080p24. And because the volume is fresh new, there shouldn’t be any bottleneck. Not for 30 seconds!
    Did you read where I say the array wasn’t able to write the 100Mbps DVCPRO HD stream, and the internal SATA drive did handle it well? It isn’t just a matter of throughput.
    There are many variables, unfortunately: QuickTime 7.1, Mac OS X 10.4.6, and the new PCIe bus, which is a big bet here. And I also read that Blackmagic Design didn’t test QuickTime 7.1 yet, so we’ll try to step down and do it again.
    Back to work! :o) Any other tips?
    Thanks anyway, Bob.
    Cheers!
    Cesar Hashimoto
  • Bob Zelin
    May 25, 2006 at 2:41 am
    250mb/sec is more than enough for you to not get dropped frames. But I just killed an AVID Adrenaline HD by loading in Quicktime 7.1, so I would certainly start there (good luck finding QT 7.0.4 – Apple is making it tough to find on the web).
    Bob Zelin
  • Kristian Lam
    May 25, 2006 at 3:59 am
    https://www.apple.com/support/downloads/quicktime704.html
    regards
    Kristian Lam
    Blackmagic Design
  • Cesar Hashimoto
    May 25, 2006 at 5:04 am
    Hey, thanks for the follow up, guys.
    We have reinstalled fresh system, sticked with QT 7.0.4 (I have the installer with me!), Mac OS X 10.4.5, tried a series of drivers and guess what. Shame sh**. No deal.
    We’re gonna test the very same workstation with a different RAID array tomorrow, so we can tell if the problem is within the workstation or the storage itself.
    This time it seems that QT is not the bad guy. :o)
    I’ll post the results here.
    Cesar
  • Bob Zelin
    May 25, 2006 at 8:02 pm
    how much room is left on your XServe RAID – is it almost full ?
    bob Zelin
  • Pete Fausone
    May 26, 2006 at 3:17 pm
    Go into the Raid Admin app in the settings panel and the performance tab. Turn off the allow cache flush, the second checkbox down on both sides of your raid. That will fix your dropped frames.
    Pete
  • Cesar Hashimoto
    June 6, 2006 at 12:02 am
    Thanks all for the help. Including the BlackMagic Design support team.
    After many, many trials, we’ve come to the fact that one of the controllers was misbehaving. It is now working full power.
    Cheers!
    Cesar
