Activity Forums Apple Final Cut Pro Legacy Dropped frames were detected during last capture attempt
  • Dropped frames were detected during last capture attempt
    Posted by Tony 456 on November 15, 2007 at 11:41 am
    Can someone PLEASE help?
    I’ve been using FCP for three years and in the past week the following problem has arisen…
    When I’m capturing footage from my edit deck I can get a maximum of five minutes, then I get the error message:
    DROPPED FRAMES WERE DETECTED DURING THE LAST CAPTURE ATTEMPT
    I’ve looked at various forums and have tried the following with no success:
    – unchecked ‘abort on dropped frames during capture’ in fcp preferences
    – added Internal HD to Privacy List in SPotlight
    – captured footgae to Exrternal HD
    – ran Disk Warrior to repair the fragmented HD
    Any other suggestions would be greatly appreciated!!
    Luke Milton replied 14 years, 11 months ago 5 Members · 5 Replies
  • Russell Lasson
    November 15, 2007 at 7:35 pm
    Just something to try:
    If you change your device control preset to non-controllable device, does it stop digitizing after 5 mins still?
    What are the specs on your system? What type of footage are you digitizing and how are you trying to bring it in?
    -Russ
  • Andy Mcentire
    December 11, 2007 at 1:38 pm
    Quicktime 7.3 can be blamed for all your capturing problems. Great job apple. Way to screw us up.
  • Luke Milton
    November 18, 2009 at 12:06 pm
    Hey,
    I recently had this problem too…
    I looked at my ‘Easy Setup…’ preferences and I realised it changed itself from DV-PAL to DV-NTSC so I changed it back to DV-PAL and straight away it sorted the problem 🙂
    I’m from the UK so obviously we use the PAL settings but as far as I know the US use NTSC so if you’re from the US I dunno if this’ll help but if you’re from the UK it’s worth having a look because apparently it can sometimes randomly change itself.
    Hope this helps,
    Luke
    https://www.bccweb.com
    lmilton@bccweb.com
  • James Mcsparron
    October 2, 2011 at 10:05 pm
    Cheers Luke. That worked!
  • Luke Milton
    October 4, 2011 at 11:17 am
    Glad it helped 🙂
