Activity Forums Apple Final Cut Pro Legacy Dropped frames or advanced rendering issue?
  • Dropped frames or advanced rendering issue?
    Posted by Garrick Simpson on March 7, 2011 at 7:10 pm
    My name is Garrick Simpson and I am a Film student in South Africa.
    While editing a recent class project i came across a minor problem. After working on an edit for roughly 2 hours, rendering as i went along, i discovered that when i played back the sequence it would play the first 2 clips, then freeze on a frame and skip the next 2 clips before continuing to play.
    I then exported the sequence using Final Cut Pro 7’s quick time conversion to see if the clip would play once exported. It did and after i exported the sequence as i said the sequence on the timeline played as well.
    Can anyone tell me what I did that fixed the problem or more specifically what the initial problem was?
    Jonathan Proby replied 15 years, 5 months ago 2 Members · 1 Reply
  • Jonathan Proby
    April 5, 2011 at 11:49 pm
    I have noticed similar problems, and it was due to playback settings being too high for the computer. Right below the sequence tab in the timeline there is a drop down menu where you can adjust playback settings. Try lowering them and see if the playback isn’t smoother
