Activity › Forums › Apple Final Cut Pro Legacy › DROPPED FRAMES Optimum settings for editing 1080i60 on FCP5?
  • DROPPED FRAMES Optimum settings for editing 1080i60 on FCP5?
    Posted by Jbooth on June 21, 2006 at 4:03 pm
    I can’t edit any of my footage without getting dropped frame warnings as soon as footage starts playing in the viewer. What are the optimum settings in FCP for editing 1080i60 on a MacBook Pro?
    Walter Biscardi replied 20 years, 3 months ago 3 Members · 11 Replies
  • 11 Replies
  • John Pale
    June 21, 2006 at 4:11 pm
    Is your MacBook Pro connected to an XServe RAID?
  • Jbooth
    June 21, 2006 at 4:19 pm
    No its not. I have imported a small selection of footage onto the hardrive and am trying to work with it that way.
  • John Pale
    June 21, 2006 at 4:49 pm
    Not going to work. You need an external drive. To work with Uncompressed HD footage, you need to use an extremely fast drive array (such as an XServe RAID). To work with compressed HD (such as the DVCPRO HD codec) you can get by with something less expensive, such as a G-RAID or Big Disk Extreme.
    Generally speaking, you cannot reliably edit with any type of footage (especially HD) off your internal laptop drive. Running the operating system and playing back the footage off the same drive is damn near impossible to do with any degree of reliablility.
  • Jbooth
    June 21, 2006 at 4:54 pm
    I’m working with HDV footage… make a difference?
  • John Pale
    June 21, 2006 at 5:02 pm
    You still need an external drive. You cannot edit off your boot drive effectively.
  • Jbooth
    June 21, 2006 at 5:16 pm
    Besides an X Serve, do you know of another portable external drive that would work for this purpose?
  • Jbooth
    June 21, 2006 at 5:21 pm
    trying a 7200 rpm external now…
  • Jbooth
    June 21, 2006 at 5:28 pm
    Same thing… dropped frames warning immediately. 7200 RPM LaCie external drive, imported one 10sec HDV clip off of it into FCP on MBPro. No dice.
  • Walter Biscardi
    June 21, 2006 at 6:24 pm
    Do your Sequence Settings match the clip settings? Did you use an HDV Easy Setup on your Mac?
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Jbooth
    June 21, 2006 at 6:31 pm
    All settings match, and I used easy set up – tried DVCPro HD codec as well. Think the issue is Firewire related. Tryin to source an external drive that spins 7200rpm with FW800 port.
