Activity Forums Adobe Premiere Pro Dropped Frames on Quicktime H.264 Export
  • Dropped Frames on Quicktime H.264 Export
    Posted by Chris Zuker on September 23, 2014 at 7:44 pm
    Hey guys,
    I am suddenly losing frames (kind of?) from my top video layer on export. Basically, on the .mov file, occasionally a frame will half-disappear from my top video layer, revealing the layer below it for just that frame. Here is a screenshot of the instance:
    8032_screenshot20140923at2.32.06pm.png.zip
    I have tried several exports and the frames that come up missing are different every time. I have tried queuing through AME, and exporting straight from Premiere, and it happens with both. It is just a rough cut with no color or heavy effects.
    I am working through a USB 3.0 drive and have my scratch disk setup for the drive, I have cleaned my cache, deleted my render files in the sequence, even tried exporting as an mp4 container, and nothing has fixed the issue.
    Here are my export settings:
    Container: Quicktime
    Codec: H.264
    Quality: 100
    1280×720
    23.976
    Progrssive
    Square Pixels (1.0)
    Bit Depth: 24
    Data Rate: 7,200 mbps
    Here are my machine specs:
    OSX 10.9.4
    2.8GHz i7 Processor
    16 GB 1600 MHz DDR3
    Intel Iris Graphics Card
    Let me know if you have seen this before.
    Chris Zuker replied 12 years ago 2 Members · 3 Replies
  • Chris Zuker
    September 23, 2014 at 8:26 pm
    This also happens when I export it as a 422… The footage I am working with is from a 5dmkiii and a C100, both of which are missing frames on the export.
  • Tina Hedegaard
    September 25, 2014 at 5:56 pm
    Are you exporting to a local or shared drive?
    Tina Hedegaard
    Technical Supervisor | Editor | Assisting Editor
    Final Cut Pro 7 | Media Composer 6.5.4, 7.0.3| Adobe Premiere Pro CS6, CC
    Mac OS 10.6.8| Mac OS 10.7.4 | Mac OS 10.8.2 | Mac OS 10.9.1
  • Chris Zuker
    September 25, 2014 at 10:11 pm
    I am exporting to the same USB 3.0 drive that I am working off of. I updated my OSX, and was able to export a cut without any issues finally. I am hoping that was the fix.
    Thanks for your reply.
