Activity › Forums › Apple Final Cut Pro Legacy › Dropped Frames – HELP
  • Dropped Frames – HELP
    Posted by Gevboston on March 18, 2007 at 12:55 pm
    I’ve just shot a DV tape and am trying to log & capture in Fianl Cut pro and I keep getting the message that there are dropped frames. The capture then aborts. I know it is set to abort but if I change that option then the vidio and audio get out of sync. I have successfully captured video/audio previoulsy. What, if any (many), setting(s) need to be changed to stop this?
    Rafael Amador replied 19 years, 6 months ago 5 Members · 15 Replies
  • 15 Replies
  • Rafael Amador
    March 18, 2007 at 1:51 pm
    Have you tried “Capture now”?
    rafael
  • Steve Connor
    March 18, 2007 at 1:58 pm
    What drive are you using
  • Gevboston
    March 18, 2007 at 3:08 pm
    yes – that’s how I capture
  • Gevboston
    March 18, 2007 at 3:10 pm
    I first attmpted to use an external drive connected via FireWire. I thought that might be the problem so I moved the scratch disk to the internal drive on my eMac. Same problem
  • Steve Connor
    March 18, 2007 at 3:39 pm
    It’s not recommended that you capture to internal drives as you can get the errors you are gettting at the moment.
    How full is the disk and how full is your firewire disk?
  • Gevboston
    March 18, 2007 at 4:20 pm
    155 gig available
  • 13 Create COW Profile Image
    13
    March 18, 2007 at 4:37 pm
    what format is your firewire drive
  • Gevboston
    March 18, 2007 at 4:39 pm
    Mac OS Extended
  • Steve Connor
    March 18, 2007 at 7:08 pm
    Do either of them have journaling switched on?
  • Gevboston
    March 18, 2007 at 8:20 pm
    I do not believe I selcted that for an option when I formatted but cannot be sure. How can I tell?
