Activity › Forums › Apple Final Cut Pro Legacy › Dropped Frames – HELP
  • Steve Connor
    March 18, 2007 at 9:33 pm
    Use the disk Utility programme, when you click on the drive it tells you the format details
  • Jason Lyons
    March 18, 2007 at 9:49 pm
    To find out if Journaling is on you can select the drive in question and do a get info (Apple-I) and look under format – it will say “Mac OS Extended (Journaled)”.
    By having successfully captured before with this machine it almost sounds like may be something OS related. You may want to clear the OS cobwebs that form from time to time between restarts. Try:
    1) Power everything down
    2) Reseat all connectors
    3) Power everything back up Restart & Try again
    If that doesnt help, try:
    – Try using a different deck/camera to source with
    – Run Disk First Aid
    – Run Disk Warrior
    Good Luck
    jason
  • Gevboston
    March 18, 2007 at 10:13 pm
    And I belive I DO NOT want it journaled? Is that correct?
  • Jason Lyons
    March 18, 2007 at 10:31 pm
    Personally I have never had a problem sourcing tons of DV footage to a drive with Journaling turned on, but I was using a Dual 2GHz G5 not an eMac, so try turning it off.
    Ken Stone covers setting up drives and how to turn off journaling here:
    https://www.kenstone.net/fcp_homepage/partitioning_tiger.html
    Cheers!
    j
  • Rafael Amador
    March 19, 2007 at 10:58 am
    Keep journaled the disks where you’ve got a system installed. The rest you can disable the journalling.
    Cheers,
    rafael
Page 2 of 2
