Activity › Forums › Apple Final Cut Pro Legacy › dropout video behind grafx
  • dropout video behind grafx
    Posted by Rick Rodgers on November 30, 2008 at 7:31 pm
    hi
    have a logo… need video of clouds to move within the logo in FCP5… created logo in PS (CS3)…
    two questions:
    do i export the logo from PS to FCP as a jpeg or tiff (need video to show)
    how do i compose in FCP to have video within the logo?
    thanks
    r
    Rafael Amador replied 17 years, 10 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    November 30, 2008 at 8:50 pm
    Create an alpha channel in the Photoshop image either inside or outside the logo area.
    You can use any alpha channel image (a Title, a Photoshop image with alpha, etc) to cut a HOLE (in it’s exact shape) and “Fill” it with other moving (or static) video… all “keyed over” another video track.
    V3: Fill clip (what you want to be “inside” alpha)
    – Select (highlight) THIS clip on V3, then:
    Modify (menu) > Composite Mode > Travel Matte – Alpha
    V2: Any “Alpha-channeled” clip (or title generator)
    V1: Background clip (will be seen outside the “hole(s)”)
    If you end up with the “reverse” of what you want, swap the clips on V1 and V3.
    Remember to change the settings (Modify (menu) > Composite Mode > Travel Matte – Alpha) on the clip that is now on V3.
    You can move/expand/reposition the V2 clip or even use it as a custom “wipe”.
  • Rick Rodgers
    November 30, 2008 at 10:08 pm
    thanks matte
    issue: i wasn’t able to import into FCP the PS doc (saved as a tiff) with alpha channels
    any suggestion?
    thanks
    r
  • Rafael Amador
    December 1, 2008 at 1:35 am
    Make sure that your Photoshop file is RGB.
    FC can not manage CYMK files.
    BTW don’t try to do it with JPEG. This format do not support transparencies (Alpha).
    rafael
    http://www.nagavideo.com
