Activity › Forums › Apple Final Cut Pro Legacy › Droplets Surprise
Droplets Surprise
Posted by Hal Beery on September 6, 2010 at 8:52 pmWhy is compressor generating a droplet on my desktop instead of the mpg2 file I sent there?
and how do I stop this action? I need that file NOW!!!!!!tnx,
Hal
MacPro Quad 2.8
OSX 10.5.8
fcp 6.03
Compressor 3.03Thomas Berglund replied 16 years ago 5 Members · 14 Replies -
Shane Ross
September 6, 2010 at 8:53 pmAre you hitting SAVE AS or something else other than clicking on the SUBMIT button?
Shane
Read my blog, Little Frog in High Def -
Hal Beery
September 6, 2010 at 9:06 pmThanks, Shane for quick response!
Not doing anything differently than I’ve ever done.
Loading the job window in compressor with destination to desktop, best 90 minute video encoding from the preset list….. hit submit.the fcp timelline is defined by in and out. nothing different or special.
also… yesterday I used compressor to encode some H.264 quick time clips for a client’s website. no problem.
tnx again,
Hal -
Hal Beery
September 6, 2010 at 9:08 pmAlso.. in the same job I tossed in the Dolby audio encoding that’s listed next to the video mpg2. It went to the desktop just fine.
Hal
Shane Ross
September 6, 2010 at 9:17 pmTrash prefs. Download the Preference Manager from digitalrebellion.com and use it. Trashes Compressor prefs. But also saved compression presets you might have made.
Shane
Hal Beery
September 6, 2010 at 9:26 pma href=’https://i1.creativecow.net/u/23743/cmprsr.droplet.jpg’>
Here’s a pic of the droplet
Hal
John Pale
September 6, 2010 at 9:42 pmCant see the whole file name, but remove any ‘questionable’ characters (punctuation, etc.).
Compressor is very UNIX under the hood.
Hal Beery
September 6, 2010 at 10:50 pmShane,
Made two encodes after trashing compressor prefs with the digigorilla and no change in results.
Trashed them again, restarted the computer, tried a short encode to test and still got the droplet, an example of which is attached above.any suggestions???
thanks,
Hal -
Hal Beery
September 6, 2010 at 11:08 pmI made all file names and sequences simple and clean. But still producing droplets. same same same same.
thanks for the suggestion anyway.
Hal
Shane Ross
September 7, 2010 at 2:27 amI’m out of suggestions…sorry.
Shane
