Activity Forums Apple Final Cut Pro Legacy droping frames capturing 24pA
  • droping frames capturing 24pA
    Posted by Reno70 on June 12, 2006 at 7:28 pm
    I am having trouble capturing in 24pA. I am using the Advanced pulldown capture preset on my G5 (4×2.5ghz/4 gb ram. – rourke data galaxy hdx SCSI). DSR-11 deck.
    I am able to capture clips up to 1 min and 30 sec. or so, anything longer than that I get a dropped frames error. Can anyone help?
    shoot.cut.score
    Reno70 replied 20 years, 3 months ago 2 Members · 2 Replies
  • Nook Kim
    June 14, 2006 at 6:39 am
    reno70,
    If you think you’re having trouble with Advanced Pulldown setting on your capture setting, try to capture as 29.97 setting. You can remove the Pulldown later on either by checking under the clip setting window, or you could even use CinemaTools.
    Hope this helps
  • Reno70
    June 15, 2006 at 7:40 pm
    thanks i’ll try it.
    reno
    shoot.cut.score
