Activity › Forums › Adobe After Effects Expressions › dropdownlist error in script UI
  • dropdownlist error in script UI
    Posted by Anton Schleitre on August 22, 2016 at 6:00 pm
    Hi there,
    I’m new to scripting and wrote a script that actually does everything I want. The only problem I got is that the dropdownlist of my UI only shows it’s contents about 90% of the time. 10% of the time the dropdownlist is just empty. I have tested it with CS4 and the newest CC2015 version. I am clueless since it works most of the time. Maybe someone sees something I don’t. Most of the time when the error occurs is when I run the script for the first time. If I run it directly afterwards it works just fine. Any help would be more than appreciated. Best Regards, Anton
    This is the code:
    (after some checks for user mistakes, function "startScript" is being called)
    var maskList = new Array;
    maskList[0] = "Like in Project Folder";
    maskList[1] = "Randomly";
    function startScript (effectName){
    var myWin = new Window ("palette", "create Object", undefined);
    myWin.orientation = "column";
    var groupOne = myWin.add("group", undefined, "GroupOne");
    groupOne.orientation = "row";
    groupOne.add ("statictext", undefined, "Please select the order of footage");
    var orderNumber = groupOne.add ("dropdownlist", undefined, maskList);
    orderNumber.selection = 0;
    var groupTwo = myWin.add("group", undefined, "GroupTwo");
    groupTwo.orientation = "row";
    var checkboxOne = groupTwo.add("checkbox", undefined, "adjusted Start point");
    checkboxOne.value = true;
    var groupThree = myWin.add("group", undefined, "GroupThree");
    groupThree.orientation = "row";
    groupThree.add ("statictext", undefined, "Apply\""+effectName+"\"");
    var PAButton = groupThree.add ("button", undefined, "Go!");
    myWin.center ();
    myWin.show ();
    PAButton.onClick = function caller (){
    //(main script, which works fine)
    Anton Schleitre replied 10 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 22, 2016 at 6:51 pm
    I can’t get it to fail. I notice that maskList is defined outside the function, which will work as long as some other part of the script isn’t messing it up. Other than that, I don’t know.
    Dan
  • Anton Schleitre
    August 22, 2016 at 8:05 pm
    Thank you for your time investigating this, Dan. It’s very much appreciated.
    maskList is not touched other than what you saw. It’s strange…
    Thanks again, Dan!
    Best Regards
    Anton
