  • Posted by Laura Cowen on September 14, 2009 at 12:17 am
    I’m getting a warning message on FCP about dropped frames. I turned down the data frame rate, put it to Safe, I turned off my computer and did everything to make it playback smoothly and it’s still acting up. I have 635 GB of free space on the ezternal hard drive that this project is running on. I have an iMac, Leopard. I had to change the sequence settings so they matched the clips and I had to rendr everything before editing..its a big project, 9 hours of small clips that are divided between 7 sequences. What could be the problem? How can I fix this annoyance?
    laura
    Shane Ross replied 17 years ago 3 Members · 8 Replies
  • 8 Replies
  • David Roth weiss
    September 14, 2009 at 12:23 am
    Laura,
    Do you have Disk Warrior? If so run it on all drives. If not, get it and run it. It’s essential for all who edit on Macs.
    Also, fix permissions on all drives using the Apple Disk Utility.
    Then, report back here and let me know how those solutions worked.
    Good luck,
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Shane Ross
    September 14, 2009 at 12:25 am
    [Laura Cowen] ” I had to change the sequence settings so they matched the clips and I had to rendr everything before editing”
    Why did you have to render? If things are set up right, there should be NO rendering. So what format are you working with? You don’t mention that. And what hard drive are you using? How is it connected?
    Shane
  • David Roth weiss
    September 14, 2009 at 12:31 am
    Shane may be onto the right thing Laura, I thought your dropped frames suddenly cropped up after you’d already been editing for a while without them.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Laura Cowen
    September 14, 2009 at 1:54 am
    I had to render because the files were .mov files and 48khz for audio insted of 44.1
    I’m using a 1tb harddrive (la cie). connected through usb. I have 635 gb of free space so its not a lack of space….
  • Shane Ross
    September 14, 2009 at 2:14 am
    [Laura Cowen] “I had to render because the files were .mov files”
    .mov files…all that says is that they are QT files. WHAT CODEC? Do FILE>GET INFO and tell us what it says.
    [Laura Cowen] “I’m using a 1tb harddrive (la cie). connected through usb.”
    USB drives won’t work for digital video.
    #43 – USB vs Firewire vs…
    Shane’s Stock Answer #43 – Types of hard drives and how they compare when working with video
    Drive types and how good they are when it comes to dealing with video…it sends data in packets or bursts, and video needs a constant steady stream.
    USB 2 = BAD
    Firewire = GOOD
    e-SATA = more GOOD
    Internal SATA = more better GOOD
    eSATA RAID = more MORE better GOOD
    4 gig FIbre = Just about the best you can get! (great for SAN networks)
    External PCIe = Da Bomb! 5 times faster than Fibre
    Shane
  • David Roth weiss
    September 14, 2009 at 2:35 am
    [Laura Cowen] “the files were .mov files and 48khz for audio insted of 44.1”
    And, in addition to what Shane said, 48khz is pretty much the standard in FCP.
    More important however are all of the other things that Shane mentioned.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Laura Cowen
    September 14, 2009 at 6:28 pm
    The codec of all the clips is HDV 720p30 quicktime.
    So do you suggest I find another hard drive that is firewire?? Is that the source of the problem (that it’s USB?)
  • Shane Ross
    September 14, 2009 at 6:45 pm
    [Laura Cowen] ” Is that the source of the problem (that it’s USB?)”
    Yes. USB is not good for editing video.
    Shane
