Activity Forums Apple Final Cut Pro Legacy Drop Frame vs. Non-Drop at 60fps and 24fps – Varicam
  • Drop Frame vs. Non-Drop at 60fps and 24fps – Varicam
    Posted by Bill Krumm on August 7, 2007 at 6:50 pm
    When the edit will be in FCP, should 24fps and 60fps be shot Non-Drop w/Varicam?
    We typically shoot our Varicam at 23.98, 29.97, or 59.94fps depending on the project. Our camera settings for each of those frame rates are set for Drop Frame timecode. When ingesting 59.94 footage into a 59.94 DVCProHD (Final Cut Pro) project, FCP appears to reconvert each master clip’s timecode to Non-Drop Frame. I guess that seems reasonable as my understanding is that FCP sequences are Non-Drop. The problem is that the ingested clip timecodes no longer match the corresponding tape timecodes, so re-batch capturing would be inaccurate. Should we change the timecode settings on our Varicam to Non-Drop when shooting 23.98 and 59.97? I don’t seem to have this problem at 29.97.
    Shane Ross replied 19 years, 1 month ago 2 Members · 1 Reply
  • Shane Ross
    August 7, 2007 at 6:57 pm
    Both 23.98 and 59.94 DVCPRO HD settings will be non-drop frame in FCP. A bit maddening, but the way it is. So yes, it would be best to shoot non-drop. Although I haven’t had an issue with batch capturing the footage a second time.
    Shane
    Littlefrog Post
    http://www.lfhd.net
