Activity Forums Apple Final Cut Pro Legacy drop frame / non drop frame
  • drop frame / non drop frame
    Posted by Michael Mcswain on August 1, 2008 at 2:28 pm
    So I searched through the fcp forum a bit but there were so many results to my search I couldn’t sort through them.. Apologies. My issue is that I have two JVC HD110’s, both are set to record non drop-frame in DV-24p. But when I capture to final cut, one is consistently recognized as drop and the other non-drop. I’m kind of baffled as to what is happening here.. Maybe its a camera issue but I thought I’d check here anyway.. I’ve also heard suggestions of selecting the clips after logging but before capture and changing the timecode to all one or the other. Any ideas?
    David Bogie replied 18 years, 1 month ago 2 Members · 1 Reply
  • David Bogie
    August 1, 2008 at 3:08 pm
    Point the camera at a sign on which you have written the camera settings at the top and the capture settings at the bottom.
    Shoot 1 minute for each of your different possible combinations of camera settings and capture settings, is that four?
    Capture at the settings specified on the signs.
    Let us know if there are any differences in anything.
    bogiesan
