Activity Forums Apple Final Cut Pro Legacy Drop Frame during Print To Video
  • Drop Frame during Print To Video
    Posted by Tntopdawg on January 23, 2006 at 10:20 pm
    I have used Final Cut for several years and have seen this only a couple of times. Usually, I have been able to restart or shut down and then work thru the problem. Today I have a show that I am trying to print to tape and the thing has hung up on me all day no matter what I have tried. Any thoughts
    David Roth weiss replied 20 years, 7 months ago 3 Members · 2 Replies
  • Thaxter Clavemarlton
    January 23, 2006 at 11:03 pm
    There is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
    You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs, sync-slippage, or freezes.
    NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
    First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    You should see a dialog box telling you its rendering.
    It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
    NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
  • David Roth weiss
    January 23, 2006 at 11:14 pm
    And, if Thax’s solution doesn’t work, check to see if you happened to upgrad to QT 7.0.4 lately. Its got problems that cause horrendous playback issues during Print to Video on machines that have never exibited such problems before. If that’s it, check on the Apple site for the rollback to a previous QT version.
    DRW
