Activity › Forums › Apple Motion › Drop down menu
  • Drop down menu
    Posted by Kevin Kimman on May 26, 2009 at 10:02 am
    Hey,
    I’m using motion for a while now, and I’m entering a project where I need to import layered files from Photoshop. But when I drag my layered .psd into the canvas the drop down menu doesn’t show, so I’m not able to choose the option to import all layers.
    I searched many forums, and apparently nobody has this problem, it should work properly but one way or the other it doesn’t.
    Please help,
    Thanks.
    Kevin Kimman replied 17 years, 4 months ago 2 Members · 2 Replies
  • Kevin Kimman
    May 26, 2009 at 2:31 pm
    Allright thanks,
    But I think I solved the problem a few minutes after I posted this.
    It turnes out that when I changed the color profile in photoshop from the standard sRGB IEC61966-2.1 to for example AppleRGB ,in the advanced options menu before opening a new project, the drop down menu in motion does show up, and I can choose to import all layers.
    So it seems that motion3 can’t see a layered .psd file when it’s made with that particular color profile…..odd enough.
    Thanks anyway
  • Stephen Smith
    May 26, 2009 at 2:32 pm
    I have had that happen every once and a blue moon. I saved the psd as a different name and that seemed to do the trick. Hope this helps.
    Lone Peak Productions
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
