Activity Forums Maxon Cinema 4D Driving X-Particles With Turbulence FD Fluids NOT WORKING
  • Driving X-Particles With Turbulence FD Fluids NOT WORKING
    Posted by Hayden Martin on December 21, 2015 at 7:01 pm
    Hi
    I’m trying to create an effect where a fluid simulation of gasses created in TurbulenceFD drives the particles in the X-particles plugin. Once I’ve done this, I plan to use X-particles’ skinning feature to texture the gasses with translucent materials to look like underwater bubbles.
    I’ve seen this technique used on these following links:
    https://lesterbanks.com/2014/09/creating-particle-advection-turbulencefd-x-particles/
    https://lesterbanks.com/2014/01/driving-x-particles-turbulence-fd-fluids-2/
    Strangely I follow each of the steps in these two videos exactly and I just don’t get the same result. In one of the videos, the tutor says that X-particles knows that it has been placed inside a TurbulenceFD container and he goes on to demonstrate it. In my case, the XP just sits, static, not following the fluid motion of TFD…
    Am I missing something? If somebody has a project file of this working it would be of great use to me to just have a look through any settings I’ve somehow left unchecked!
    Really baffled!
    Thanks for your time
    Hayden
    Burak Gür replied 9 years, 4 months ago 3 Members · 3 Replies
  • Felix Frank
    November 6, 2016 at 7:40 pm
    Same issue here
  • Felix Frank
    November 6, 2016 at 9:15 pm
    You have to activate in the TFD container>simulation tab>velocity tab> particles velocity scale to 100%
  • Burak Gür
    May 26, 2017 at 11:33 am
    You need to check `cache velocity` on the tfd container before simulating.
