Activity Forums Adobe After Effects Driving green screen- green reflection in glasses causing an issue.
  • Driving green screen- green reflection in glasses causing an issue.
    Posted by Levi Pounds on February 8, 2014 at 4:52 pm
    Hi all. Disclaimer: I am relatively new to AE and have been using tutorials to learn over the past month or so.
    I have just finished locking the picture edit for a TV pilot I am editing. It is not VFX heavy (single camera style comedy) but there is one driving green screen scene. 3 angles- a head on two shot through the windshield, and a profile shot of both actors.
    My issue is with the head-on shot through the windshield. I managed to get a reasonably good key using the technique in this tutorial: https://www.videocopilot.net/tutorial/advanced_soft_keying/
    The problem is that the actor in the driver’s seat is wearing glasses that produce a bar of green reflection which allows the background plate to show up over one of his eyes. Screen shot attached. A friend of mine suggested this could be fixed with a simple garbage matte. I’m really not sure how to execute this. Any help would be greatly appreciated.
    View post on imgur.com
    Levi Pounds replied 12 years, 7 months ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    February 9, 2014 at 2:49 am
    A garbage matte prior to keying will not do the job – all it’ll do is prevent the green bar from being keyed. I assume that this is what you’ve done. Hence, the green bar on the glasses.
    You have to do the following –
    1) track the green bar
    2) create a patch to cover the green bar
    3) apply the tracking result onto the path in (2)
    Good Luck
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Darby Edelen
    February 9, 2014 at 6:29 am
    You can use a mask on the original footage to hold out the green section of the glasses. Then you can remove the green using your despill technique of choice.
    Darby Edelen
  • Levi Pounds
    February 9, 2014 at 4:30 pm
    Thanks for the tip.
    Excuse my ignorance but when masking the original footage, do I use the pen tool to select the area I’d like to isolate? When I do this is seems make everything outside the mask black. Is this done with mutiple layers or is there a setting I should turn one.
    Basically what I’m asking is how do I tell after effects “do not key this area”.
    Levi
  • Levi Pounds
    February 9, 2014 at 4:49 pm
    So I used two layers with the mask on top. I used colour suppression on the top masked layer and that seems to have done it. There is still a reflection but it is not green.
    Much better. Thanks both.
