Activity Forums Blackmagic Design driver install fails
  • driver install fails
    Posted by Jason Maloney on February 10, 2006 at 1:19 am
    I have one Decklink Extreme system that will not install drivers. I have done a complete clean install of windows and Adobe Production Bundle 2… however, running the Decklink driver install works – but the device will not install. In device manager it shows as “Other PCI Bridge Device” — In comparing this with my 2 other systems — the difference that is obvious is in the Device ID property… The other two systems show as PCI\VEN_10B5&DEV_A100&SUBSYS_A10010B5…. but this card shows as PCI\VEN_10B5&DEV_9056&SUBSYS_905610B5….
    Is this an early version of the card that the new drivers are not recognizing???
    Any help is appreciated.
    Shane Chadder replied 20 years, 7 months ago 2 Members · 2 Replies
  • Jason Maloney
    February 10, 2006 at 1:25 am
  • Shane Chadder
    February 10, 2006 at 2:16 am
    Jason
    In Device manager right click on the “other bridge device” and select uninstall to remove the driver. Then rerun the decklink install as a repair.
    That’s my best guess.
    Shane
