Activity Forums Apple Final Cut Pro Legacy Drive takes a while to mount/eject
  • Drive takes a while to mount/eject
    Posted by Goro Toshima on January 7, 2011 at 6:16 pm
    hi all,
    i’m editing a project on FCP.
    recently, the drive has been taking a while (couple minutes) to mount and eject when i start/end the day. it was never like this before.
    is this something i should be concerned about?
    thanks for any help.
    goro
    Goro Toshima replied 15 years, 8 months ago 2 Members · 2 Replies
  • Todd Gillespie
    January 7, 2011 at 7:42 pm
    That defiantly doesn’t sound good.
    Empty Trash, restart, run Disk Permissions/Repair on the HD for starters.
    I would guess that either the drive has a problem or there’s an application that’s hanging it up. Try making sure all the applications are closed, see if it ejects faster. Try on another Mac (if you have one) if it’s still slow to eject, then you’ll know it’s the drive. You could try something like Disk Warrior, but if it’s a hardware issue it won’t help.
    Good Luck,
    Todd at UCSB
    Television Production
  • Goro Toshima
    January 8, 2011 at 6:58 am
    thanks for the info. todd.
    i’ll try what you suggest.
