Activity › Forums › Adobe After Effects › Drifting displacement map trouble…
  • Drifting displacement map trouble…
    Posted by Josef Brett on February 17, 2013 at 9:36 pm
    I am trying to use a displacement effect in AE CS6. I have a multi-layered project – a woodland scene with a ballet dancer in it. The ballet dancer is keyed footage and the woodland shot I am using as the background has a left to right track. To keep the ballet dancer in place, I have created a track on a null object and parented the ballet dancer layer to it.
    When i apply the displacement effect to the background layer and use my ballet dancer layer as the displacement map, the resulting displacement effect doesn’t seem to take the track into account.
    The displaced figure ‘drifts’ in the woodland scene – moving away from the other effects I have created around the placement of the ballet dancer (all attached to this tracking null).
    How can I get the displacement effect to respect the track please?!
    Any help would be most welcome.
    Thank you.
    Ashish Gupta replied 13 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
  • Josef Brett
    February 17, 2013 at 9:52 pm
    Hi Dave, thanks for the suggestion, but that doesn’t work, unfortunately. I need to parent the dancer to the tracking data to get her to sit in the scene correctly (i.e. to move with the camera movement of the scene).
    It’s frustrating as I have tried pre-comping the dancer etc and nothing works!
  • Vishesh Arora
    February 18, 2013 at 4:41 am
    josef
    Have you tried precomposing the Keyed Footage? Try precomposing the Ballet Dancer Footage and then use this Precomp as displacement map. Precomposing solves many issues.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Ashish Gupta
    February 18, 2013 at 8:48 am
    Josef ,
    U have to precompose the ballet dancer layer along with the track ..
    Displacement map doesnt take into account the animation done on the displacement map layer in the same comp it takes only alpha values from the map … so if u want to have an animated displacement map u have to precompose along with your animation in and in your case tracking…
  • Josef Brett
    February 18, 2013 at 9:37 am
    Ashish,
    Thank you! I think that will work. I will try it when I am on the computer.
    Thank you all for your replies.
    Joe
  • Darby Edelen
    February 23, 2013 at 10:10 am
    [josef brett] “It’s frustrating as I have tried pre-comping the dancer etc and nothing works!”
    Enable collapse transformations on the pre-comp.
    Darby Edelen
  • Darby Edelen
    February 23, 2013 at 10:16 am
    [Ashish Gupta] “so if u want to have an animated displacement map u have to precompose along with your animation in and in your case tracking…”
    You can pre-compose and Leave Attributes and set the pre-comp’s collapse transformations switch on. I do this a lot for these sorts of animation unaware effects (Displacement Map, Compound Blur, Set Matte, etc.)
    The advantage is that you can animate in the parent comp without having to drill down into the pre-comp.
    You may need to move some effects into the pre-comp depending on what your set up is. The displacement map will see the transforms in the parent comp but not the effects.
    Darby Edelen
  • Josef Brett
    February 23, 2013 at 12:50 pm
    Thanks for all the help.
    This is resolved now – I duplicated the tracking null and pre-comped it with the ballet dancer and then used the pre-comp as the displacement map.
  • Ashish Gupta
    February 26, 2013 at 2:31 pm
    Darby,
    i just tried it .. Great tip .. thanks .. !!
