Activity › Forums › Maxon Cinema 4D › Drape “cloth” over a cube
  • Drape “cloth” over a cube
    Posted by Tony Barone on January 9, 2012 at 10:21 pm
    I remember seeing a tutorial somewhere, and for the life of me I can’t remember where, on how to drape an object as if it were cloth over another object.
    For example, if I have a plane object, and wanted to drape it over a cube and have it stop where it touches the cube, but drape over the edges like a table cloth.
    Can someone please explain how to do this?
    Tony Barone replied 14 years, 8 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    January 10, 2012 at 3:06 pm
    The best way to do it is to use the cloth simulation system, if you have it in your C4D package. It’s pretty simple. Position a subdivided plane over your cube, convert it to polygons, give it a Simulation>Cloth tag. Add a cloth collider tag to the cube. Press play. Adjust the cloth tag settings to taste.
    If you don’t have cloth you can get a so-so result using a soft body simulation tag.
  • Tony Barone
    January 10, 2012 at 3:33 pm
    EXACTLY what I was looking for!
    Thank you!!
