Activity Forums Adobe After Effects Dragging a layer (left and right) in timeline without moving keyframes?
  • Dragging a layer (left and right) in timeline without moving keyframes?
    Posted by Yoshiko Tanaka on November 26, 2014 at 10:59 pm
    Hello,
    I have a newbie question. I would like to drag a layer in timeline (left and right) without moving keyframes that I made for position. In the layer is a pre-comp. Is it possible?? Please advise. Thank you millions in advance!
    y
    Graham Macfarlane replied 11 years, 10 months ago 2 Members · 1 Reply
  • Graham Macfarlane
    November 26, 2014 at 11:45 pm
    Hi Yoshiko,
    Whilst not a perfect solution, you should be able to use the pan behind tool to help with this.
    If the precomp is fully extended to its limits in the timeline (you will see the little black triangles in the top corners of the layer) the pan behind tool won’t do anything.
    Therefore, first, you need to trim the in or out point to where you need the layer to start or finish playing (short cut: Alt+[ Alt+] )
    Then use the pan behind tool to drag the layer to match that trimmed in or out.
    Finally fix the trim on the other end of the footage as needed.
    Graham Macfarlane – CGI specialist
    Elyarch Ltd – London UK
    3D Studio Max | Vray | Pflow | PhoenixFD | After effects | Mocha
