Activity Forums Adobe Premiere Pro Drag-select edit points without the playhead moving?
  • Drag-select edit points without the playhead moving?
    Posted by Royce Jacobs on October 6, 2024 at 8:21 am
    Drag-selecting edit points with the Rolling Edit Tool (N) makes the playhead jump over to them and it makes me sad. So I have to select end points one-by-one and hit E (cumbersome with multiple layers of clips). I do understand Shift-Q/W will extend Next/Previous edit to playhead, but that means changing track targeting every time to make sure it’s not grabbing upper/lower-track clips way down the line. I just want to drag-select what I’m looking at without playhead movement. And to go searching for the destination point again after selecting seems like an unnecessary task… I’m usually near or right on the destination point when I decide to do the edit, so pre-selecting the edit points then finding the destination is not a natural sequence of events, in my brain anyways.
    No combination of modifier keys seems to make a difference and I see nothing in prefs to change this behavior. Even (ctrl) drag-selecting with the regular Selection Tool has the same effect.
    Am I possibly missing something? Thanks for any help 🙏
    Nick Ha replied 3 months ago 4 Members · 10 Replies
  • 10 Replies
  • Devrim Akteke
    October 6, 2024 at 12:11 pm
    You can use Command Drag or Control Drag on a Mac or a PC and select those edit points without moving the playhead.
  • Royce Jacobs
    October 6, 2024 at 1:47 pm
    Hi there thanks for the reply but I’m afraid that’s not the case on my machine. I tried all modifier key combinations, if it selects the edit points, the playhead moves. Maybe there’s a setting I missed? Can you confirm if your Premiere behaves this way by chance?
  • Devrim Akteke
    October 6, 2024 at 5:16 pm
    Yes, that’s the correct behavior. You should select an edit point first then shift select other edit points, this way playhead does not move.
  • Royce Jacobs
    October 6, 2024 at 5:59 pm
    I’m confused by your first post then. The point of my question was to find out an alternative, but thank you though.
  • Devrim Akteke
    October 6, 2024 at 6:16 pm
    Yes, I missed that one. Unfortunately, it is the way to go.
  • John Hepworth
    January 15, 2026 at 5:36 pm
    Is there no workaround for this? Like in the original post, I often am sitting where I want to extend to, and just want to lasso the relevant tracks and have them extend or whatever to my playhead.
  • Devrim Akteke
    January 16, 2026 at 5:41 pm
    So I have a video here to clarify what is needed. I drag-select the edit point with the command key. Playhead moves to the selected edit point, and I can drag the cursor to the time that I want to extend, and I can extend with a keystroke or by dragging the edit point. I can do a regular drag or ripple extend. Does this workflow work, or is it something else?
  • Royce Jacobs
    January 17, 2026 at 6:09 am
    Well so the point of this thread was that the “Playhead moves to the selected edit point” part is what we want to avoid. When you’re using spacebar/arrow keys and find that exact frame you want to move the edit points to, you don’t want to have to find it again after the playhead moves from having selected the edit points. It seems like a forced order of operations that you have to select your edit points first before finding the point in time you want to extend them to.
    I was originally posting just to try to find out if there was a way to do avoid that order.
  • Devrim Akteke
    January 17, 2026 at 10:29 am
    Well, yes, unfortunately, there is no way to avoid that.
    Adding a sequence marker may help to find the frame you want to extend.
  • Nick Ha
    June 12, 2026 at 11:33 pm
    hi, i know i’m extremely late to this, but while i haven’t found a way to disable the playhead movement, i found a workaround that prevents it from moving!
    there’s a keyboard command called “select nearest edit point as roll”. if you tap this key while holding or dragging the playhead, it’ll select the nearest edit to the playhead without moving it (on targeted tracks, at least). subsequent keytaps will add more edits to the selection.
    combine this with the “extend selected edit to playhead” commands, and you basically never ever ever have to manually select clips ever again.
    tl;dr:
    * start dragging your playhead around the relevant edit points
    * tap “Select Nearest Edit Point as Roll” as many times as you need
    * tap “Extend Selected Edit to Playhead” to move the edits
    there’s extra selection types as well, like “select next / previous edit point as ripple / trim”. heck, you can skip selecting by using “trim / ripple / extend next / previous edit to playhead”.
    with these commands, you can pretty much just hold LMB indefinitely to drag your playhead around, and make all your edits that way, without ever having to click even once. heck, you don’t even need to use LMB if you use the “move playhead to cursor” command.
    it’s actually a bit wild how much this has sped up my editing workflow!
    here’s an example, and also a list of the most relevant keyboard commands for this workflow:
