Activity Forums VEGAS Pro Drag and dropping multiple transitions – a better way?
  • Drag and dropping multiple transitions – a better way?
    Posted by Matt Malkin on May 17, 2010 at 4:55 pm
    Basically I have to edit many video for my business and the transition I use is the page peel. I use 4 different page peels to mix it up a bit. The question is: Is there a way to apply them to the clips in one go. The videos I edit are made up of lots of 30-60 sec clips about 20-30mins long. Currently I drag and drop them in one after the other. If not how can I disable the pop window that comes each time you drop it in? Many thanks in advance, Matt.
    Matt Malkin replied 16 years, 3 months ago 4 Members · 4 Replies
  • Mike Kujbida
    May 17, 2010 at 5:08 pm
    “Is there a way to apply them to the clips in one go.”
    Because you’re using 4 different page peels, unfortunately no.
    If you weren’t, you’d make sure all events were set to the basic dissolve, select all of them and drop the desired transition anywhere.
    All the dissolves would now be the new transition.
    “…how can I disable the pop window that comes each time you drop it in?”
    Hold down the Shift button and then drag the desired transition down.
    BTW, this works for applying most, if not all, FXs too.
  • Theo Van laar
    May 17, 2010 at 6:17 pm
    ‘Basically I have to edit many video for my business and the transition I use is the page peel. I use 4 different page peels to mix it up a bit. The question is: Is there a way to apply them to the clips in one go’
    This could be done easily by using a scripts like Excalibur
    Theo
  • Aleksey Tarasov
    May 18, 2010 at 3:47 am
    Scripts greatly simplify this task.
    You can freely download and try Vegasaur ( https://vegasaur.com )
    It includes the Quick Properties tool, that perfectly solves your problem
  • Matt Malkin
    May 18, 2010 at 8:49 am
    Hi
    Thanks everyone I’ll give those things a try. Much appreciated.
