Activity › Forums › DaVinci Resolve › DR and Boris Continuum OpenFX issue
  • DR and Boris Continuum OpenFX issue
    Posted by Kenneth Maultsby on December 11, 2020 at 3:00 am
    All I am experiencing an issue with DR and Boris Continuum. When I add a transition or filter, it will forever to render, and the playback on the clip would be slow and jitter. These are OpenFX—no issue when I use Resolve FX. I also have Magix Vegas Pro on the same PC using the same Open FX and have no problems. I have already reinstalled both applications. Need help.
    Glenn Sakatch replied 5 years, 9 months ago 2 Members · 1 Reply
  • Glenn Sakatch
    December 13, 2020 at 5:05 pm
    Its not unheard of for some plugins to be a beast. You didn’t mention any system specs, so its hard to say “your system is underpowered” or “hmmmm should fly on that box” I wouldn’t expect real time playback on all boris fx plugins. Some will be worse than others. Taking forever to render…I guess that depends on your definition of forever. Is the box actually stopping…1 or 2 fps render, or is a 10 min clip taking 20 to 30 mins to render? If it is a 1 second clip, and it’s taking 5 mins to render, than, yes, I would say you have an issue.
    I wouldn’t compare Boris to Resolve fx. One is built and tuned specifically for the program…another is not.
