Activity Forums DaVinci Resolve DPX to FCPX workflow – correct aspect ratio?
  • DPX to FCPX workflow – correct aspect ratio?
    Posted by Joe Rigby on January 25, 2016 at 12:30 pm
    Hi there,
    I have 7 DPX clips which were converted from 16mm. The frame size is 2048×1240 and it’s 25fps. Each of the 7 DPX clips have a different starting timecode 01:00:00:00 – 07:00:00:00
    I’ve test the workflow and it all seems to work well at this stage:
    In Da Vinci create 7 timelines with the start timecode adjusted to relate to each DPX clip
    Export Prores Proxies
    Edit in FCPX
    Export XML
    Import XML into Da Vinci
    Grade (the DPX have a “Technical Grade” on them from the post house and don’t have as much scope in the grade as I had hoped, but that’s a different issue!)
    Deliver
    My question is what aspect ratio should my timelines be?
    My 1-7 timelines in Da Vinci should be 2048×1152 16:9? There’s no 2048×1240 option, is 2048×1152 the best one to go for? I’m picking it as it’s closest to 2048×1240. I know it doesn’t matter too much at this stage as I’m just making proxies, but it does make a difference in the offline as the HD clip is either an overscan with black all around or full height with black at the edges.
    My Prores Proxy files are 1920×1080 – that’s fine
    My FCPX timeline is 1920×1080 – that’s fine
    But when I import the XML back into Da Vinci, even if I un-tick sizing information my timeline is 1920×1080, so I have to make a 2048×1152 timeline and copy and paste all the clips into that?
    What’s the best size timeline to master in? I know it’s probably a stylistic choice but is there a timeline where the DPX will be full frame with no black around?
    Thanks in advance,
    Joe
    Tero Ahlfors replied 10 years, 7 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    January 27, 2016 at 7:18 am
    [Joe Rigby] “What’s the best size timeline to master in?”
    In what resolution are you supposed to deliver the film in?
