Activity › Forums › Adobe After Effects › DPX In & DPX Out of AE Without Modifying Header Info etc?
Posted by Jay Lee on September 14, 2009 at 11:24 pmGood evening all,
For reasons I wont go into I am needing to bring one HUGE long LOG DPX 2K sequence into AE and then split it into certain takes and render those out as DPX sequences. Is there a AE workflow that allows us to output these DPX with out changing header information or any LOG characteristics?All thoughts most appreciated.
Cheers,
J
Jay Lee replied 17 years ago 3 Members · 5 Replies -
Chris Wright
September 14, 2009 at 11:55 pmdpx and cineon’s advanced settings should be looked over and tested thoroughly. This includes color management.
https://magazine.creativecow.net/article/cineon-files-what-they-are-and-how-to-work-with-them
https://technicolorsoftware.hostzi.com/
Jay Lee
September 15, 2009 at 12:06 amHi Chris,
Thank you for your response. Yes……..these settings a good place to start however a particularly intimidating dialog box/settings that have the potential to do more harm than good.Instead of rendering out the DPX sub-sequences is there a way I can determine in AE what frame range the DPX clip is and then simply extract those frames from the master sequence with a simple copy and paste in the OS explorer??
Cheers,
J -
Chris Wright
September 15, 2009 at 12:28 am“With Glue Tools Cineon/DPX Pro for Final Cut Studio, you will be able to read and write Cineon or DPX digital images in one easy step. You no longer need to convert your source frames into another format using a separate program such as Shake, Combustion or other Open Source packages. You can work directly with the native images themselves. At last there is an easy way to load and save Cineon or DPX film (or High Def) images into QuickTime.”
https://www.gluetools.com/products_dpx.html
Peter O’connell
September 15, 2009 at 1:20 amHi, if you open a DPX file in a text editing program, there is likely some timecode and frame number info on the very first line or 2 that you might be able to use that is human readable.
PeteRogue Keyframe
Feature Film Compositing -
Jay Lee
September 15, 2009 at 1:57 amThanks guys……..these DPX sequences headed straight for Color and then back to AE. Not sure Glue Tools as a one time only investment would fly.
Peter text edit tip helpful thank you.
The question still stands though………if in AE we have a section of a larger DPX sequence residing in a composition is there away to determine its actual range of frames?Cheers,
J
