Activity › Forums › Adobe After Effects › DPX Fps interpretation in AE
  • DPX Fps interpretation in AE
    Posted by Daniel Bruylandt on February 19, 2009 at 11:58 pm
    Hello,
    I’m working on vfx (AE CS3)for a movie, shot in 16mm film 24FPS.
    I received from the lab, 2K DPX 10bit log files. (First time I work on that type of workflow).
    Then I have to render it back with the same specs…
    My problem is :
    When I import the DPX sequence in AE, the default frame rate of each DPX shots is set on 25FPS.(And it should be 24fps)
    Does it mean there is a problem with the DPX files (25fps instead of 24fps), or I just have to set the “interpret footage” settings of each shots manually on 24fps? (as the comp)…
    Thanks for your attention
    Dan
    Daniel Bruylandt replied 17 years, 7 months ago 2 Members · 2 Replies
  • Peter O’connell
    February 22, 2009 at 7:18 am
    Hi, try this, within the Preferences>Import dialog. Set the Sequence Footage value to 24. Now all sequences will import by default at 24.
    Pete
    roguekeyframe.com
  • Daniel Bruylandt
    February 23, 2009 at 12:11 am
    Thanks for your answers.
    I think I’ve solve my problem.
    I’ve made a test render of a DPX sequence at 24fps, then re-import the sequence in AE and the interpretation is still at 25fps
    So, I think that the problem is only because I’m working with a PAL system…So my AE settings are set at 25fps.
    Thanks anyway
    Dan
