Activity Forums AJA Video Systems dpx export problems
  • dpx export problems
    Posted by Senthil Kumar on November 19, 2010 at 11:09 am
    Hi
    I am trying to convert the captured duallink video from telecine in fcp using the aja 10bit rgb codec, the converted DPX from the aja qt to dpx utility looks faded, like blacks look grey,
    what is the procedure to convert the aja 10bit rgb coded video to DPX??
    regards
    senthil
    Senthil Kumar replied 15 years, 10 months ago 2 Members · 2 Replies
  • Gary Adcock
    November 19, 2010 at 2:50 pm
    [senthil kumar] “the converted DPX from the aja qt to dpx utility looks faded, like blacks look grey,”
    That would be because you are looking at a LogC interpretation of your original, correct?
    “what is the procedure to convert the aja 10bit rgb coded video to DPX??”
    Use the included AJA QTTODPX translator, it is in the Aja Utilites folder to convert your QT movie to frames.
    I personally use VTRX to capture directly as DPX over DL, saves the secondary step of conversion.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Senthil Kumar
    November 20, 2010 at 6:40 am
    Hi Gary,
    i have-been using the QT TO DPX utility only , but on converting the RGB video QT the DPX looks faded like LOG images,
    what is the procedure to convert to DPX with the Correct colurs with out using the aja utility
    thanks
    senthil
